For reasons too weird to actually mention :) i need to retrofit my pre-lci to lci center console.Just the console.
I know that the lci console does not have the ashtray & 12v source anymore; they've been moved instead below the dvd/cd slot. Question: if i buy a lci center console and the lci bit that goes below the cd slot -and has the 12v volt source- would i be set to go or will i get mentally insane by realizing the myriads other-things-you-need-to-do-before-this-works-because-this-is-BMW ? Any info/views ? Thanks |
I have to ask why.....................
you should be able to route the connectors of the cig lighter to the new location...
look at the CIC retrofit in the DIY section for tips I guess.. |
Originally Posted by Martin525i
(Post 1268610)
