Center console-rear-light bulb change
Originally Posted by nonames123' post='750987' date='Dec 22 2008, 11:18 PM
How do I change the light bulb on the center console rear 12.5volt DC power plug. The right amber ring burned out.
Thanks for the help
Thanks for the help
If it is the same as my car, the panel on the back of the center console gives the passengers two 12v outlets. The panel actually pulls out if you gently pry it out using leverage from putting your fingers in the outlet holes (sounds bad, I know).
From memory, the bottom of the panel should come out first because the top has a recessed bezel that rest underneath the vents that are above this assembly.
Once you have gotten this far a trip to your local BMW parts counter should be all you need.
My Ride: 2007 Sapphire Black Metallic 525i. Beige Dakota Leather, Premium package, bluetooth, BMW Assist, Xenon adaptive lights, Sirius radio
Originally Posted by nonames123' post='751021' date='Dec 22 2008, 11:03 PM
ANYBODY?
let me know if I can be of any further assistance.
Originally Posted by nonames123' post='751741' date='Dec 23 2008, 09:27 PM
Thanks a million - I will change them out this weekend. I will let you know how it turned out. Thanks again
My Ride: 2005 (01/05 Build) Titanium Silver Metallic 530i, Black Dakota Leather Interior w/Dark Poplar Wood Trim, Cold, Premium & Sport Packages, Steptronic, Bluetooth
MODS: OEM 166's (M5 Offset) on General's (245/35 & 275/30), 15mm H&R Spacers, Auxiliary Audio Input, 6000K Xenon Headlights and Matching HID Fogs, AIB v3.0, SprintBooster, OEM LED License Plate Bulbs, Smoked LED Side Markers, Matte Black Kidney Grills
Just for kicks, i take a look at the rear outlets in my car (always driving, which is definitely not a bad thing) and I got the same problem, one of the light rings are out. Good to know there's an easy fix
TexaZ3
05-06-2015 09:54 AM
