CCC Coding Recommendations - Chicago
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
Hi there,
Swapped out the dead CCC with a replacement from getbmwparts.com.
Now the programming. The functions not working now are logic 7, voice command, and PDC.
Any recommendations (Indy/etc) in the Western Burbs or Chicago?
Thanks
Thanks
My Ride: 07 550i Sports Package
You need to have the CCC recoded, you can do it if you have someone with a OPS with the optical connection, or ISTA. Do not attempt to do it over ODB port it can take up to 10 hours and will likely fail.
You might as well give up on voice command you will likely never have that again. The voice command needs a FSC code to activate. It is very expensive to get from the dealer and you will need it on a disc to use with Progman or you would have to take your car to the dealer and have them do it after you have already programmed the CCC with your VIN.
DavaiLave
08-02-2022 02:16 AM
