CAR WOULD NOT START
Old Oct 15, 2009 | 12:42 PM
royalflush408's Avatar
Angry
Hi
My battery works... I can roll down window, turn on radio, alarm from the key, etc.... But car won't start. Don't know what's wrong???
Can anyone help
Thanks
Old Oct 15, 2009 | 12:51 PM
gbaty0001's Avatar
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
your battery could be just below enough power to crank but still have power to due those actions such as windows and lights. You may want to try and charge your battery. Hope it works out.
Old Oct 15, 2009 | 12:59 PM
sdg1871's Avatar
My Ride: See my signature
Originally Posted by royalflush408' post='1033300' date='Oct 15 2009, 04:42 PM
Hi
Can anyone help
Thanks
Your starter could be bad. It happened to mine and it needed to be replaced. The starter replacement in the E60 is a long and expensive repair because many parts need to be removed to access the starter.
Old Oct 15, 2009 | 02:20 PM
How much would starter cost, roughly??????
The car was working fine. Even took it out last night, no problem... But today when I tried to start, bad luck!!!
Old Oct 15, 2009 | 02:24 PM
sdg1871's Avatar
Mine was done under warranty. The biggest hit is the labor. Dealer said that the repair would have cost somewhere about $2K-$3K if not under warranty.
Old Oct 15, 2009 | 04:06 PM
nfs060's Avatar
Try charging the battery, best bet. Any warnings.
Old Oct 15, 2009 | 04:21 PM
luigi524td's Avatar
Thumbs down
Or try a jump start to rule out the starter as the problem. Accessories like windows and radio don't require the juice necessary to start your car. Battery replacements are a common service issue. If you're out of warranty try one of the direct fit replacements available at any decently stocked retail auto parts store like Autozone, etc.
Old Oct 15, 2009 | 05:02 PM
I just tried jump start... Nothin happened.
I'm assuming its the starter's problem???
Old Oct 15, 2009 | 05:05 PM
sdg1871's Avatar
My starter problem involved the failure of the solenoid. So when I tried to start it, the starter would "click" like crazy but the engine would not turn over.
Old Oct 15, 2009 | 05:13 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
first things first, is the car shifter in park?
