car wont start =(
+1
A low battery can do incredibly strange things to an E60. Its whole existence is built around a steady voltage and plenty of current.
Usually the easiest place to start is by measuring the battery before you try to start it (voltage is measured under the hood at the battery jump terminal and ground terminal near the drivers side strut tower. A healthy battery should be 12.6V fully charged. Once it is below 12.1V starting is very iffy. Jump only under the hood.
Once started, give it about 15 seconds for the alternator to stabilize and then measure the system voltage. If it is not 14.1V - 14.6V then your alternator may be dying.
If the alternator is good then as pcy says, drive it for 1/2 hour to fully charge the battery. Then turn the car off and let it sit a couple of hours for the surface current to leave the battery. Then measure it again. If it is below 12.5V then chances are you need a new battery.
If the battery measures 12.5V to 12.6V after a few hours then measure it again the next day. If it has run down overnight then you may have something staying awake in the car which is running down the battery. For early model E60s if the IBS is damaged by moisture it is famous for partying all night and keeping the ECM awake which runs down the battery fast.
Yes, if you start with a known fully-charged battery, disconnect the BSD line (blue plastic connectors) and wait a day or two you will know.
Not sure exactly when the change was made. Improved encapsulation for better water proofing was implemented in the 2007-2009 range, but I'm not sure exactly when, and may even vary from model to model. Realoem lists a series of obsolete part numbers for the IBS for the 2004 545i, suggesting the part went through a number of iterations.
If so, I should just leave unplugged and be good to go, right?
I have an 07 but will give it a try tomorrow. Seems every time I wash car I have issues with battery after, yet I can't find any water in boot, wheel well, etc. Now I am thinking maybe the moisture is causing the IBS to act up.
When the IBS is unplugged the ECM will default and charge the car with a steady 14.3V, which is acceptable for either AGM or FLA batteries.
AN IBS should run a couple of hundred bucks if you shop around on the Web.
Awest91
Sep 17, 2022 11:05 PM
