Car started to shake
Old 12-02-2012, 06:29 PM
Original's Avatar
My Ride: 2010 535i M sport
Model Year: 535i / 2010
Default Want to upload images
Want to upload images on a post but do not know.
Can someone tell me steps by steps?
Last time I tried I was ask for the URL from where the images where.
They where on my downloads from my documents didn't know what to do.
Please advise.
Thanks
Old 12-02-2012, 07:26 PM
AchtungE60's Avatar
My Ride: E60 530i
Be aware of what other members are telling you to do. I've seen some new members here with no credibility or experience (I can tell from posts) giving advice. Each BMW is different. You have an LCI and different engine than me for example.
Did you check the coils to see if you have an issue with them? Perhaps they're not performing at 100%. You do not need OEM plugs or coils. Personally I go with Bosch Platinum +4 and they run about $6 each and have 5 yr warranty. They are an OEM item.
You may start having issues with the pulse sensor on this engine. There are 2.
You may start having Mass Air Flow Sensor issues.
You may start having carbon build up
You may be starting to develop a vacuum leak and will have to trace it out with smoke.
It's hard to tell but if you don't have error codes on the car then it could very well be a vacuum leak.
Old 12-03-2012, 08:38 AM
Persian_535i's Avatar
No error codes being thrown? If so post those codes.
Old 12-03-2012, 11:12 AM
Original's Avatar
No erros yet.
Here are few images of the carengine
Attached Thumbnails Car started to shake-throttle.jpg   Car started to shake-front-engine.jpg   Car started to shake-08-528i-engine.jpg   Car started to shake-throttle2.jpg   Car started to shake-top-front-engine.jpg
Old 12-03-2012, 04:07 PM
AchtungE60's Avatar
My Ride: E60 530i
When I worked on this engine, there was a stupid little sensor inside the valve cover and it was a 10 hour job. i replaced the valve cover gasket in the meantime because it was a pain in the arse and it was a $300 sensor. I am glad I have an M54
Old 12-04-2012, 02:28 PM
alisaeed03's Avatar
My Ride: 535i Platinum Bronze, Cream Beige Dakota Leather, Sport Package, Paddle Shifters, Window Curtains, Nav, Heated seats and steering, 5% tint, 6000k HID, 2500k Fogs, 7000k Angel Eyes, Black Grill, Black Emblems, Tinted Head and Tail lights, Logic 7
Wait, so you fixed the problem?
Old 12-04-2012, 02:53 PM
balbs's Avatar
My Ride: BMW
Did it start shaking after the spark plug change? Maybe one of the ignition coils was not put in properly. Mine did that when one of the ignition coils was going bad.
Old 12-04-2012, 06:41 PM
Original's Avatar
It was shaking before I replace them. I was hopping by changing them it was going to solve it, but it didn't. I did not replace the coils they look fine to me and didn't want to spend $250.00 just to find out.
Does any of you think that the rough iddle and shake can go away by changing the coils?
Please advise.
Thanks
Old 12-04-2012, 06:57 PM
balbs's Avatar
My Ride: BMW
The best thing to do is use a diagnostic tool to look at codes. If it 's a coil, you can just replace the affected one.
Old 12-04-2012, 07:12 PM
Original's Avatar
Is there such tool that I can buy myself and test it? Can there be erros in the system without having any check engine lights? Please advice.
Quick Reply: Car started to shake
