Car Stalling
Gentlemen, today, my car stalled three times while moving. Each time, the stall occurred when I was braking. My RPM meter seems to dive when the car is coming to a stop. When the car stalled, the meter dropped too suddenly.
When I put the H&N filter in the car a couple of weeks ago, the car started to make some strange RPM movements at the lower speeds.
Any relationship? Does the computer have to be reset with the H&N filter to accommodate a better flow of air?
Perhaps I got a bad tank of gasoline. I am not sure.
Any thoughts?
Any thoughts?
Try throwing in the old paper filter and see if the problem goes away. If it does then you may have over oiled your K&N air filter.
Did your check engine light come on?
Ugh oh! I have it on mine, too. ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
monacobmw, please do as ImolaRed suggested and report back to see how it goes?![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
I have no issue so far with K&N filter![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Thanks in advance.
Thanks in advance.
I have no oil on my K&N filter. Should I?
Originally Posted by monacobmw' post='363441' date='Dec 4 2006, 10:27 AM
The check engine light does come on.
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package
Modifications:
M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher
Next planned mods:
?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
Mine has never stalled too, in fact the car feels smoother than before.
Did you remove the charcoal filter? If so that has an effect. And if you also change filter media the "fuel/air ratio" changes and the oxygen sensor may not be able to compensate since you don't have a 'throttle body" but have to depend on valve lift.
