Car Sputters at 4000 rpm
Old 08-02-2012, 01:21 PM
jfondell's Avatar
Just as the title says my 2006 525 is sputtering at 4000 rpm and up. It seems like its missing? Any ideas before I take it to the dealer? Plugs and cooling system are good? Maybe restricted fuel filter?
Thanks
Old 08-02-2012, 01:30 PM
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
Do you have a way to read the fault codes and see what it thinks is wrong? May be something simple like an ignition coil, which you can easily replace yourself. No point paying the dealer to do that.
Old 08-02-2012, 01:35 PM
jfondell's Avatar
Yes I will read the code and see what it says. There is nothing on the IDrive.
Old 08-02-2012, 01:40 PM
Wolrab's Avatar
Misfire from a bad coil may not show up on the I-drive. Happened to me recently - the I-drive finally bong'd when it got really bad, and gave me an e-bollocking about misfires feeding gas to the cats and causing environmental problems. Turned out to be just one coil out of 8.
Old 08-02-2012, 01:43 PM
jfondell's Avatar
P1017 code but thats been on there since I bought the car? It wont erase the code?
Old 08-02-2012, 03:27 PM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
That is you eccentric shaft sensor (Valvetronic) going bad. You should have it replaced. May try doing it yourself if you are good with a wrench.
Old 08-07-2012, 06:09 AM
jfondell's Avatar
Ok car is at the dealer with a 5000 bill. I got the valvetronic sensor replaced oil pan gasket and rear drivetrain all replaced. Thank
God it's under warranty! Gonna cost me 560 for deductible. I think I am going to extend the warranty. Thanks for the heads up about the sensor
Old 08-07-2012, 07:07 AM
jgt
jgt's Avatar
My Ride: E60
Engine: N52
Rear drivetrain? Can you please elaborate?
Old 08-07-2012, 08:46 AM
jfondell's Avatar
They said everything suspension related except springs and shocks as I just replaced them.
Old 08-07-2012, 12:01 PM
Wolrab's Avatar
Please let us know if replacing the Valvetronic sensor fixed the misfiring problem. Thanks...
Quick Reply: Car Sputters at 4000 rpm
