Car Shaking at Idle (Increased Emissions) !!!
I know I have to bring this one in for the dealer to check but if you guys could help me diagnose the problem that would be great. The car shakes really bad sporadically at idle and sometimes stalls. The service engine soon light is on and it also says Increased Emissions. The dealer already cleaned out my Fuel Injectors and I was told that some cylinders are Misfiring possibly. Anyone have any ideas on the cause?
Thanks
Mike
516-902-7866
Thanks
Mike
516-902-7866
My Ride: 2005 545i Sport 6MT
Thanks
Mike
516-902-7866
Thanks
Mike
516-902-7866
Originally Posted by 05545i' post='1069573' date='Dec 7 2009, 06:09 PM
You can try replacing the pressure regulator valves (pcv valves). I know that several people have had that same problem you're having and they were fixed by replacing both of them. There about 35$ each from the dealer. You need two of them. How many miles on the car? Probably not a bad idea to change plugs either.
Thanks again for your help!
Mike
Originally Posted by mk23169' post='1069602' date='Dec 7 2009, 06:51 PM
How hard are they to replace? Do I need my mechanic to do it? (I'm not that great with engines). I think they changed the spark plugs on my last service. The car has 101000 miles on it.
Mike
Mike
don't know if this will help but sure worth the try. very easy to do.
https://5series.net/forums/index.php?showto...p;#entry1004699
good luck
good luck
