Car says coolent is too low
Old Jul 28, 2009 | 08:28 AM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
Just got a call from the wife and she said the car gave a message that the coolant is too low. Not sure what would have happened to the coolent, hope I don't have a gasket problem, I'm out of warranty.
Is there a special type of coolent that I need to buy or just go to any parts store and top up under the hood?
Old Jul 28, 2009 | 08:32 AM
e60hodzic530's Avatar
My Ride: 550
i put the 50/50 diluted coolant from autozone..i believe its called PEAK and the bottle is blue it seems to do the job for me
Old Jul 28, 2009 | 08:56 AM
vaca's Avatar
I would suggest getting the BMW coolant from a dealer, only $20 or so for a gallon and mix it 50/50 with distilled water and use that to top off the overflow tank.
Pretty simple.
Old Jul 28, 2009 | 08:58 AM
Howitzer's Avatar
Where is the cap for the darn thing even located? LOL
Old Jul 28, 2009 | 09:06 AM
mhs525's Avatar
I got that message about 6 months ago. Coolant was low, don't know where it went, maybe evaporated slowly over the years. I added some antifreeze into the overflow tank and no problems since.
I used the everyday stuff.
Old Jul 28, 2009 | 09:07 AM
Gene's Avatar
known issue/warning...most dealerships will do a complimentary top off when you stop by the service department....had one about 9 months into my e60 (brand new)
Old Jul 28, 2009 | 09:19 AM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
Pretty simple.
You can buy Prestone 50/50 for closer to $10 a gallon, or you can buy pure antifreeze for even less and mix it yourself. It works just as good.
Old Jul 28, 2009 | 10:49 AM
1esquire's Avatar
My Ride: 2009 DINAN 135 convertible
I had the same issue, and I just added 16 oz of tap water to it (for $0/gallon). I figured w/the amount of antifreeze in the system, adding 16 oz of straight water won't dilute it enough to cause any issues (maybe I'm 47/53 now instead of 50/50).
Old Jul 28, 2009 | 11:40 AM
stoic1's Avatar
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
I had this happen to my 545i just recently. Before this though I also received a message twice saying the fluid was low in the expansion tank. Concerned, I took my car to an independent garage (out of warranty) where I found out that I had a coolant leak on the back side of the engine block (valley pan gasket). The leak wasn't very bad, but considering how hot its been in Texas I didn't want to take any chances and bit the bullet and had the problem fixed. After having the car in the shop for 3 days and about $1800 later the car is running fine.
Old Jul 28, 2009 | 12:49 PM
D33ZNUT5's Avatar
Ouch I hope thats not my problem! Wife called back and said after a short drive the message went away so hopefully it is just a tiny bit low. My car was parked on an incline so that may have had something to do with it.
