car revving weird at idle
Old Feb 1, 2011 | 05:04 AM
aarnoldupenn's Avatar
My Ride: 05 525i
This morning driving to work, I noticed the RPM needle was hovering at 750, then it would dip to maybe like 650-ish then go back up. I turned the stereo off and I could here a humming sound then it would cut out a little then go back to normal. While driving it seemed fine.
Anyone else experience this? Fuel Pump maybe?
525i btw.
Old Feb 1, 2011 | 05:12 AM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Owners here on the forum have experienced similar symptoms while their alternator was on the way out...
Might want to look into that.
Good luck!
Old Feb 1, 2011 | 05:16 AM
My Ride: 05 525i
Thanks, I'll get that checked at.
Old Feb 4, 2011 | 08:59 AM
sel1oner's Avatar
Had this exact issue in my 550...
Completely went away when I had the brake vacuum recall done. I was leaking a decent amount of oil around the pump and I'm guessing it may have been messing with the vacuum pressure and causing the idle to fluctuate when the car was stopped. When driving, there were no noticeable issues.
As, the 6 cylinder doesn't have the vacuum pump issue, I'd check around for a vacuum leak elsewhere, maybe a disconnected hose or someplace where air can be entering/escaping the system.
/jack
TexaZ3
Apr 8, 2015 10:50 AM
thesalboy
Apr 8, 2015 09:13 AM
Stranger12
Apr 5, 2015 10:42 AM
Sic Sticks
Mar 30, 2015 01:17 PM
james69z28
Mar 23, 2015 06:45 PM
