car jerks forward when stopping
My Ride: Stock 2004 BMW 525i
If there are any leaks they would be visible on the ground most of the time. I am thinking that there is either a internal issue or could a low fluid level cause the "jerking" you are experiencing?
Good luck.
Good luck.
put in sport mode while on idle shift from 2nd to first see if it slams sometimes is won't but most of the time it will but your problem is defiantly a tranny issue your tranny pan might need to be serviced really hard to tell but defiantly tranny needs attention very common with our cars
My Ride: 2005 545
Sounds like the second to first gear slam,, ( serge ) when coming to a stop , with foot on the brake . Feels like your getting rear ended .
A transmission update did the trick on my car with that exact problem . Been fine since then ,and has never done it again ...
My Ride: 2005 bmw 530i
sport mode you mean put it to the left and shift manual.and can you get a transmission update anywhere or just the dealer.
My Ride: E60 530d
My Ride: 2005 545
My Ride: 525d M Sport
That sounds exactly like mine!
