Can you tell if a rim is bent or not with your eyes?
Old Aug 30, 2007 | 01:44 PM
soliterry's Avatar
Is it possible to judge whether a rim is bent or not with your eyes in real life or do you need some sort of machine to balance and tell?
Old Aug 30, 2007 | 02:47 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Sometimes yes, sometimes no.
A significant bend can be visible to the naked eye but more often than not, minor bends aren't as easy to see...
Old Aug 30, 2007 | 03:05 PM
AlwynMike's Avatar
My Ride: Estoril Blue 440i GC
Model Year: 2017
As Rudy says, it has to be a pretty serious lump to see without spinning the wheel.
I would recommend jacking up the car so the offending wheel is off the deck. (usual disclaimers about chocking opposite wheels, not getting under the car, etc. apply). To start with, spin the wheel and see if you can spot a bend in the rim. Do the same for the inner rim of the wheel. If you have a minor bend, it will probably be on the inner rim, as they don't have as much support as the outer. If you think you can see a bend, get some blocks of wood and build yourself a small tower so you can place something close to the rim (a spanner is as good as anything, but a steel rule is good too. A dial gauge micrometer is probably taking it too far!!). Secure this with another block on top. Spin the wheel again and look at the distance between the rim and your spanner or whatever. This should obviously remain constant. If your rim is bent, it won't. It is quite surprising how even just a mark on the tyre can fool the eye into thinking that a rim is bent. The edge against the rim is proof one way or another. It's all your Dealer will do, although he may take the wheel off and put it on his balancing machine to spin the wheel.
Mike
Old Aug 30, 2007 | 03:39 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I think the Hunter Road-Force balancing machine that many dealers use will determine not only if a wheel is bent but also where the bend is. It's an amazing piece of equipment...
Old Aug 31, 2007 | 04:03 AM
Palmo's Avatar
My Ride: E60 525d M-Sport Saloon M57N2 3.0d LCI EXTERIOR: Jet Black, ///M-Aerodynamic Bodystyling, ///M-Rear Spoiler, De-badged, Gradual Tint Windscreen, ///M-Double Spoke 172M 19" Alloy Wheels (with non-run flats & space saver spare wheel) & ///M-Sports Suspension; INTERIOR: ///M-Steering Wheel, Black Dakota Leather Heated Sports Seats with Electric Lumbar Supports, Brushed Aluminium Interior Trim & Anthracite Headlining.
I'll second that - excellent piece of kit. This has certainly sorted a number of balance problems I've had in the past on other cars that 'standard' balancing machines could not solve.
They are extremely rare though here in the UK - I have a 120 mile journey (each way) to the nearest garage that has one! I think there are probably only 10 or so places nationally that have one (according to the Hunter website).
Does the BMW dealer Network use these machines in the US?
Old Aug 31, 2007 | 04:16 AM
E60BEEMER's Avatar
Talking
Certainly, as you can see the contour of the wheel, ideally you got to take of the rim from the car to see properly. But the outside rim is usually hit inwards, i have some wheel experience as i workied in K ONE WHEELS in Green Street, and i chnaged my wheels on my E36 about 7 times in the 5 years that i kept it.
However on the E60 i have only chnaged wheels twice from Original, 2 times.
I have this problem with my E90, the wheels have been torchered by curbs and high end pavements, women drivers unfortunately.
I,l put some pics of it up and you will see what i mean, totall disgusting, ive also been told that these wheels have to go as they are too badly damaged and that i will have to replace them at some point soon.
E60BEEMER
Will get some E90 Bad wheel pics up shortly
Old Aug 31, 2007 | 04:22 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I don't know if the US BMW dealers are required to have them but it's possible that they are recommended. I'm sure my dealer has one and I seem to recall reading a TSB that suggests road force balancing as a remedy to an issue...
Old Aug 31, 2007 | 06:13 AM
E60BEEMER's Avatar
Talking
See the state of these wheels
you can see on one pic from the curve that its buckled inwards which in turn affects the camber and toe, which knocks the tracking
balancing of the wheels is done
Old Aug 31, 2007 | 06:32 AM
C's Bimmer's Avatar
Jesus man...tell me that's not your car! If it is, someone needs to learn how to park. That's some serious curb rash!
Old Aug 31, 2007 | 10:49 AM
i think from a past post sometime those wheels are on his 3 series? well, that hurts to see more than worn out shoes on a nice car.
