Can I Swap My Standard Seats for Multi-Function Seats
I have the standard heated seats; not the sport seats or comfort seats. I want to swap out for heated multi-function comfort seats. After some help from Rudy and the search feature, I have found that the comfort seats and the sports seats pretty much share the same wiring harness. Where as the standard seats evidently have a different one.
Can anyone tell me how big of a project I am looking at? Can I (or the dealer) adapt a new harness or modify the existing one? TIA
My Ride: `04 645CI Convertible
`06 535D M-Sport
I`ve heard about the standard seats having a diff. wiring harness and you will need reprogramming after install too!
Here in holland there`s a shop selling the multi. comfort seats, all complete with installation for 3k euro`s
, and you`ll have to leave your old set behind.
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
My Ride: 545 SE Auto in Black
it would be a ball ache to do its not a plug and play job thats for shure your need to make a loom tap it into the fuse box etc etc get it coded get the brains with the seats its a lot of hassle but you could do it as a project.........
i did this from standard part electric non heated cloth (cant get worse than that) to M5 20 way sports heated memory seats...it was a nightmare, the wiring is compleatly different and the coding took a bit also, in total it took 3 days and cost me ?750.
it was all done OEM by mark at cartronics (byfleet UK)
and everything functions perfectly.
dont forget you will need to swap over the seat belt pre tensioners also as there different for the sports seats, and these need coding also
but yes its do-able
but yes its do-able
but yes its do-able
but yes its do-able
My Ride: 525d SE
I replaced my cloth semi electric seats for heated memory electric sports seats and they work with the exception of the memory which i need to get programmed next time i have something else programmed. I was a pain but certainly can be done
Try looking at a topic "M5 fully electric seats" by "drantispy"
My Ride: 2010 M5 alpine white, black full leather, etc.
The easiest and best way to do it is to get a new vehicle! That is what I did. More warranty, more features, more power etc. for not that much more money with all the deals floating about right now. Replacing the seats could also become quite a headache if every little piece of minutia is not perfectly done.
