Can I rotate my tires?
I have a 2005 525i and I was wondering if it is ok for me to rotate my tires. I'vbe heard conflicting statements on this subject. Some saye that BMW recommends that you don't. If I should rotate them is it ok to do at it a tire shop or do I need to do it at the dealer? The dealer wants about $80 Discount Tire was $25 to rotate and balance. I want to make sure that my tires last long.
My Ride: various
Model Year: F10 2015 M Sport 530d
if you mean rotate as fit fronts to the back and vice versa...
....then it should be fine if all your wheels are the same size, (the ones in your picture are)
they should already be balanced fine
just do it yourself for free
If all tyres are the same size you can and should rotate.
Always put the better ones rear.
My Ride: Hayabusa, with Tbo and E60, with Tbo
Yes, absolute can chance side to wheels... If You have sportpackage, then take wheel from rim and chance it to other side of car...
Extend lot of mileges to wheels..
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
If you're keeping them on the rims, why would they need to be rebalanced?
If all 4 tires are the same size, then you should always rotate and balance your tires for more even wear. I think the industry standard is to rotate and blanace your tire every 5 to 6K miles, which in conventional cars is every other oil change. You should choose the cheapest place as long as you can guarantee that the cheaper place won't scratch your wheels.
Originally Posted by CTYankee' post='269762' date='Apr 16 2006, 02:33 PM
If they are non-directional (i.e. no arrow molded into the tire) I would use traditional rotation scheme: LR to LF, RR to RF, LF to RR, RF to LR. If they are rotational, switch same sides: LR and LF, RR and RF.
Every mile upsets the balance........ don't believe me take yours off and see
chadillac2000
42
09-13-2017 11:15 AM
