Can any expert help me with some oxygen sensor questions?
Old Oct 10, 2012 | 10:49 AM
hzhang's Avatar
Default Can any expert help me with some oxygen sensor questions?
Hi there
I have a 2004 525i and want to replace the oxygen sensors.
1) I checked online and found that not only they are expensive, but the 4 sensors are differently priced. Just curious why the two upstream ones are different and the downstream ones are different from each other.
2) there are some cheaper sensors (APwi brand) compared with Bosch or ntk. I am wondering anyone used those?
3) where is a good place to buy the sensor wrench?)
Thanks in advance. Any advise/comments are greatly appreciated.
HB
Old Oct 10, 2012 | 05:52 PM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
Hi HB,
The 2 pre-cat are really the ones you need to replace. Stick with OEM Bosch on these. As far as price, they are different lengths and the insulator is a different color so that is reason enough for them to stagger the price.
Old Oct 10, 2012 | 08:40 PM
hzhang's Avatar
Thanks, only bimmers
Old Oct 11, 2012 | 05:26 AM
luigi524td's Avatar
Originally Posted by hzhang
Hi there
HB
Has your car thrown codes that lead you to believe the O2 sensors need to be replaced? Generally these work until they don't. And they will "code" -- sometimes - meaning sometimes O2s are replaced but the codes persist because it was really something else that failed.
Old Oct 11, 2012 | 07:28 PM
hzhang's Avatar
thanks. No code yet. But according to the manual Bentley I need to replace the oxygen sensors at 120000 miles for e60 m54 engine. I figured sooner or later I will do this, why not now and follow the manual.
Thanks again.
Old Oct 12, 2012 | 12:24 PM
Bimster530i's Avatar
My Ride: 530i
+1 Stick with Bosch/OEM O2s
Get a "crow's foot" style O2 sensor wrench. The ones that look like a deep socket with a split up the side for the cable usually don't fit the BMW O2 sensors.
Many auto parts stores have these wrenches in stock for ~$10.
Old Oct 12, 2012 | 07:32 PM
hzhang's Avatar
Thanks for the advise. I decided to buy both.
Appreciate your time.
windnsea
May 25, 2015 09:49 PM
ashamlawi
May 8, 2015 06:50 AM
coolspot
May 7, 2015 05:50 AM
carid
Apr 29, 2015 04:20 AM
brian1225
Apr 16, 2004 05:59 AM
