can active steering be disabled?
My Ride: Current - 2004 BMW 545i M Sport, Silver Grey, Auto, Remus Sports Muffler, BMC Air Filter.
Previous - 2005 Ford Falcon XR6 Turbo, Auto, BMC Air Filter.
Originally Posted by turboawd' post='867245' date='May 4 2009, 12:27 PM
can the active steering be disabled by pulling a fuse maybe? will i get warning messages?
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Originally Posted by chris_545i' post='867458' date='May 4 2009, 08:25 AM
You should be able to disable it by pressing your DSC button and holding it until it deactivates, apparently that turns off DSC/DSP and active steering.
Never heard of it before
Originally Posted by keith84_uk' post='867459' date='May 4 2009, 05:35 PM
Deactivating the DSC will turn off the active steering???
Originally Posted by chris_545i' post='867462' date='May 4 2009, 08:41 AM
It's written in my car manual...steering also feels different too (545i)
hmmmm
With the DSC system active, the active car can steer itself in a critical situation.
You can't turn the active steering off, just the DSC system.
From bmw.com:
If the vehicle is threatened with instability, such as by oversteering or braking on a changeable surface, DSC identifies the problem and can use Active Steering to help overcome it. For example, in order to reduce unsafe yaw, Active Steering can increase the angle of steering wheels faster than even the most expert driver.
Source: http://www.bmw.com/com/en/insights/technol...e_steering.html
From bmw.com:
The AS is definitely disabled on my 2006 if you turn off DSC and DTC (hold the button as said above). It feels completely different and requires more lock to turn.
Unfortunately doing this also disables the cool "keep you from oversteering" feature, which is helpful on the way to work.
Originally Posted by E60Sim' post='867493' date='May 4 2009, 04:08 AM
hmmmm
From bmw.com:
From bmw.com:
Haaber det gaar godt i Koebenhavn
