camshaft position bank 1
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
Hi all can some help on this was on motor way and I went to put the boot down and eml light came on code poo15 is this camshaft sensor and is this the one on the right side of the vanos solinoids oh I have a e60 523i 2.5 tanxs all appreciate the help regards ian
My Ride: BMW 550I BLK
Engine: N62
I had a 04 530i with the same code and more codes followed. Check your manifold adjuster unit, there's a plastic flap that breaks off. After I kept getting bank one bank 2, o2 sensor and mtf and misfire codes and spending all kinds of money. It was the manifold adjuster unit causing all those codes. I paid $254 usd on line for the part. You can replace the flap cheaper but I just replaced the whole unit.
Model Year: E60
Engine: 2.5
Ok tanxs a mill but are sure it's not the camshaft position sensor that's what that code is saying I'm confused
Engine: N62
Ur right there was nothing wrong with my cam shafts sensors or none of the other codes that popped but bc i didn't know any better at the time I went and paid for all new parts according what was associated with the code. Later on to find out it was a broken flap on my manifold adjuster unit aka: DISA valve
