CABD ERROR while coding CCC mask2
Old Feb 25, 2025 | 12:23 PM
pastaboi's Avatar
My Ride: BMW E61 535D 2004
Engine: M57
Default CABD ERROR while coding CCC mask2
I have tried to default code a previously fitted ccc mask-2 unit from the owner before me, but none of the options in threads I found have worked. I tried basically everything, checked that everything is set up right, sp-daten are updated and so on. The only error I end up when I try to communicate with any of the CCC ECU modules I have are nicht antworten, or in english, not responding. I came here to search for an answer, because I am in fact very troubled with the fact that nothing that helped others has helped me . If anyone wants to look closer into the errors or help me, please contact me. I also have teamviewer and can show you everything, or you could try to fix it remotely if anyone would be such a good soul.
Best Regards,
Pastaboa
Old Feb 25, 2025 | 01:19 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
If you install AnyDesk I can look and see what's going on with it.
Old Feb 25, 2025 | 01:34 PM
pastaboi's Avatar
Engine: M57
Of course! Since I can see you're from Augusta, were in different time zones and I am 6 hours ahead of you. Would it be okay for you tomorrow at 14:00 your time? We can exchange contacts so I can send you the anydesk ID better.
Old Feb 28, 2025 | 10:54 AM
To close this out needed to change VO to default code MASK2. Vehicle had 609 and 620 and it only needed to be 606. Also, LCI typecode needed to be entered with updated build date. Only wrote 606 to CAS/LMA. Kept the rest of the VO in modules intact.
Dom Paulauskas
Aug 13, 2015 04:38 AM
clu7ch
Aug 11, 2014 09:08 PM
wokingBigBoy
DIY: Do It Yourself
Apr 17, 2013 12:49 PM
picman
DIY: Do It Yourself
15
Jan 11, 2013 04:51 AM
BallyM5
May 7, 2012 07:09 AM
