A/C Pro Needed - 06 530i E60 AC Blowing Warm Air & misery. i have scan tools & cider
Old 02-27-2018 | 04:28 PM
  #61
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Let me check mine off but I'm sure your readings are not going to be accurate with the car off
Old 02-27-2018 | 05:13 PM
  #62
Model Year: 05 530i
Engine: 3.0 M54
Mine show 80 low 110 high with the car off. Car on it shows 34 low 146 high.
Old 02-28-2018 | 01:18 AM
  #63
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Originally Posted by Ohainey
So I put the gauges on the blue 528i and they are reading 100 psi low and high when car is not running. Is that normal ?
I'm pretty sure the a/c was working on this car before I ripped tranny.
If the AC has not been used for a long period, I would think that those readings look normal. The high and low side will tend to equalize after a long time of non-operation. The good news, I suppose, is that you don't have a leak in that system!
Old 02-28-2018 | 10:18 AM
  #64
Ohainey's Avatar
My Ride: 2006 E60 530i,
Time to swap 528i compressor into 530i.
Old 02-28-2018 | 10:19 AM
  #65
Ohainey's Avatar
Thanks sean time to stop fucking around and start doing some good olde fashioned wrench pulling and knuckle busting.
Old 02-28-2018 | 02:40 PM
  #66
Model Year: 2005
Engine: N62
Good luck.
Old 02-28-2018 | 02:48 PM
  #67
Ohainey's Avatar
Good luck.
Thanks.
Quick question. I'm in store looking to buy socket set. The special bolts and the tensioner on the BMW. Are they just standard e sockets and star bits ?
Old 03-01-2018 | 12:30 AM
  #68
Model Year: 2005
Engine: N62
Thanks.
Can't answer you there - I am but just a dumb engineer and I leave that esoteric stuff to my mechanic.
Old 03-01-2018 | 12:49 PM
  #69
Ohainey's Avatar
They are E-Sockets and Star Bits
plus a T60 to turn the belt tensioner.
Old 03-01-2018 | 09:15 PM
  #70
Ohainey's Avatar
It was the compressor.
Put it in the 528i compressor which was exactly the same.
Boom
I pulled a vacuum on it on it and it did the very same. Lost -30psi to zero in less then 15mins. But it took the Freon no problem and started cooling right away.
I will I’ll keep you posted on if it holds a charge, and I’m going to double check the gagues on another car with vacuum.
Thank you you for all your help. When I get settled after this I will put up a post with everything I learned.
Quick Reply: A/C Pro Needed - 06 530i E60 AC Blowing Warm Air & misery. i have scan tools & cider
