A/C do not chill
Hi
There is a problem with my A/C it do not chill the air.
The system is just refilled 820g R134a coolant fluid. (Don't know what it's called)
If I lower the temperature setpoint then the fan is running faster but the air is still same temp as outside.
Any of you had the same problem?
I could take my car to the dealer but already spent money on a refill which did not help.
Thanks fo any help.
Thanks fo any help.
My Ride: 2004 525ia, Olivin green, active steering, sunroof, bi-xenons, power assist, bluetooth phone system, Professional stereo with navigation, sprint booster, Goodyear F1 235/40x18 for in town drives, 16's for country roads
Hi
Thanks fo any help.
Thanks fo any help.
Hello' My 2004 525 a/c took very long to start cooling sometimes especially if car engine was warm. dealer changed a/c compressor under BMW goodwill to fix problem. Good luck!
Hi
Thanks fo any help.
Thanks fo any help.
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Did you check the temp setting in Idrive under climate? If the colored bar next to the seat is red , adjust it so that is blue...
If that does not work sounds like a dealer related trip could be coming up.
My Ride: Type 523I UL (EUR)
Dev. series E60 ()
Line 5
Body type LIM
Steering LL
Door count 4
Engine N52
Cubical capacity 2.50
Power 130
Transmision HECK
Gearbox MECH
Colour TITANSILBER METALLIC (354)
Upholstery LEDER DAKOTA/SCHWARZ (LCSW)
Prod. date 2006-05-15
Order options
No. Description
1CA SELECTION COP RELEVANT VEHICLES
2NP M LT/ALY W. DOUBLE SPOKE 135 M W.RUNFLA
235 TRAILER-HITCH WITH REMOVABLE HEAD
302 ALARM SYSTEM
337 M SPORTS PACKAGE
339 SATIN CHROME
4M3 INTERIOR TRIM.FINI. ALU. CUBE PURE
428 WARNING TRIANGLE
442 CUPHOLDER
465 THROUGH-LOAD SYSTEM
470 CHILD SEAT ISOFIX ATTACHMENT
481 SPORT SEATS F DRIVER/FRONT PASSENGER
494 SEAT HEATING F DRIVER/FRONT PASSENGER
502 ; HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
522 XENON LIGHT
534 AUTOMATIC AIR CONDITIONING
540 CRUISE CONTROL
698 AREA-CODE 2
704 M SPORT SUSPENSION
710 M LEATHER STEERING WHEEL
715 M AERODYNAMICS PACKAGE
775 INDIVIDUAL ROOF-LINING ANTHRACITE
8SA COUNTRY SPEC. RELEASE OF NAVIGATION
8SP COP CONTROL
842 COLD CLIMATE VERSION
850 ADD FUEL TANK FILLING FOR EXPORT
863 EUROPE/DEALER DIRECTORY
877 DELETION CROSS-OVER OPERATION
885 SWEDISH/OWNERS HANDBOOK/SERVICE BOOKLET
896 DAYTIME LIGHTS FUNCTION
9AA EXTERNAL SKIN PROTECTION
Series options
No. Description
216 SERVOTRONIC
08 535i sport pkg
07 E61 530Xi
No problem ,It's a common problem that many drivers don't know about.
My Ride: 2004 Silver BMW 525i, loaded w/o Nav
2007 Ford Expedition Eddie Bauer, loaded w/o Nav
Our problem is similar- At night, or when the car is moving- A/C is on point...
But, if you park that bad boy and leave it idling, it heats up REAL quick. I'm worried because I live in TX-
I checked the vent settings and all of that- the man's chest is blue on both the driver and passenger vent settings.
Then again, in the wintertime, sometimes the heat would shut down too- and later come back up. I'm thinking it may be settings related, but it looks like I have every thing set right. Not sure why stopping and idling (my wife ran into a store for a minute while I sat outside. After about 10 minutes, I had to let the windows down. Five minutes after that, I was in the store too) causes the AC to stop working.
I've always said this is the one area the USA (HVAC) has the advantage over all other automakers.
