A/C compressor clutch pulley question...
I notice that the clutch pulley on my A/C compressor rattles a little (Bearings gone bad?). Can the clutch pulley be replace by itself or does it require replacing the A/C compressor?
Has anyone done it? Any DIY?![Please](https://5series.net/forums/images/smilies/imported/please.gif)
Thanks
Thanks
My Ride: 545i sport
I believe the compressor clutches are available but not readily. A shop that specializes in rebuilding compressors can replace the clutch and check out the entire compressor in the process. Will be significantly cheaper than replacing the compressor/clutch assembly. Most larger cities have a/c specialty shops that will rebuild your compressor.
My Ride: 05 BMW 530I
If you cant there is a cheaper solution other than going to the dealership. Look at the link below for a replacement compressor.
Denso $323
Expansion Valve $16
Drier $9
Denso $323
Expansion Valve $16
Drier $9
PelicanParts.com
09-10-2015 10:02 AM
