business navigation system ?!
in my country we dont have navigation system yet, but i will get my new 525 car after 2 weeks with business navigation system, so what can i use it for? or it dosnt function at all ?
thanks
thanks
My Ride: E60 545i, 2004. Alpine white, ventilated seats, confort seats, bluetooth, HI-FI Audio, Electrical Rear Blinds, manual Side blinds, Sport Package, Confort Glass,Active steering, Business Navigation
thanks
thanks
[snapback]164426[/snapback]
Regards
My Ride: 535d
If you cannot get a navigation map, I suppose you can at least get a GPS signal and thus, you may select the "car position" item in the nav menu. This gives you the position in degrees and the altitude.
This is not so much but it is already something.
Please notice that there are software for pocket PC that allow you to scan almost any map and let you define two point to navigate then on the map. You may use you car GPS to "feed" the software and with an additional antenna, you may then navigate on the map using you pocket PC. Of course, you will still not have the route calculation...
Bank$hot530
07-12-2015 04:36 PM
