BURNING OIL SMELL FROM VENTS
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
I would also suspect the valve cover gaskets. Most of the time, they start to leak in the back of the engine (in the lower corner). Oil is dripping directly on the catalytic converters causing that oil burning smell.
It is pretty hard to see that leak from the top. You need to remove that metal reinforcement plate under the engine and see if there is some oil on it. Then you have also some access to see the valve cover from the bottom.
That job on 545i and 550i is pretty expensive ? it can run anywhere from $1300 to $2300+ (depending if you want to replace the spark plug tubes and upper chain cover gaskets).
This may be helpful
https://5series.net/forums/topic/930...r-gasket-545i/
This may be helpful
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
My Ride: 530i
PelicanParts.com
08-14-2015 10:15 AM
