Broken plastic piece after dealer cigarette lighter repair – help iden
My Ride: 530i n52
I'm sure one of the experts can help. It appears to be a retention tab, as you probably already figured. It may explain the loose trim. Have you checked behind it? GL.
I had the AC's regulator changed do to failure in my '05 525iA and they broke the console (see pic).
After a very long story they got it right.
There are no loose parts in a E60, have them to get it right.
It would be nice to know your whereabouts!
My Ride: 530i n52
There is no way for me to remove it because it's firmly attached on the right side. If you look at the picture posted by "Ricracing", it's loose where the left heated seat activation button is. There suppose to be a tab inside that gets pushed down with a screwdriver on both sides to release the trim. But I have no idea what it looks like.
I'm from USA. Updated my profile just now.
Check realoem.com
RealOEM.com Home => Select your car => Vehicle trim => Instrument carrier / mounting parts
From the pic, it looks like that piece was molded as part of the dash. I'm also guessing that is why your trim is loose. Not an easy or cheap fix.
Originally Posted by ObD' post='864679' date='Apr 30 2009, 07:35 PM
Check realoem.com
Awest91
Sep 17, 2022 11:05 PM
TexaZ3
May 6, 2015 09:54 AM
