Broken Head Bolt - $2,800!!!
A head bolt is what holds the cylinder head to the engine block. If this was broken, you would likely blow your headgasket.
The problem isn't common but it isn't rare on the N52 either.
I am constantly amazed at how much great information is out there if you look for it and how many great people give up their valuable time to share it all!
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
If you come to Richmond you can try Richmond Bmw west broad street and ask for Tommy Fagen a younger master tech that is the only person that works on my car he may have a suggestion t tand or may do the work for you in his spare time he has worked on my car and my other e34 five lots of times for me at his leasure no promises but worth a try
Final Update!
I got the car back a couple of days ago from Eastern Autowerks in Norfolk, VA. They did a great job.
I had the valve cover gasket and the broken head bolt replaced. As you can imagine the cost was significantly less than the dealer! I have been driving the car hard for two days and not a drop of oil has appeared anywhere on the engine from the valve cover or the head gasket. Time will tell but I am confident that this is fixed.
Thanks again for all of the help and input!
Engine: 530i
good deal man I hope it holds if you dont mind telling what was the cost and how many miles do you have on your car
For the valve cover gasket and head bolt was just over $600. They took care of some other things while the car was there also. My car is just over 91k miles.
jluzbet
11-07-2015 01:25 PM
