Bridgestone RF weight comparison
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Originally Posted by katheikia' post='244911' date='Feb 23 2006, 12:59 PM
Does anyone know if the Bridgestone RFs weigh more than the same size Michellin PS2s?
A good place to check such things out is tirerack.com. If you go there, then "save" your car first. Then, seek info about tires or wheels--depending on what you are interested in. Usually, you can easily find the tires you are interested in and then use the "Specs" links, as I recall, to get the kind of info you are seeking.
Edit: I should have said before that I am positive that the PS2's are much lighter than the RFT's you mentioned. I wasn't sure how much lighter though.
My Ride: 2006 550 SMG
Thanks
Model Year: 2015
Engine: N55
Bridgestone RE050 RFT 245/45/17 95W =32 pounds
Michelin PS2 245/45/17 95Y = 24 pounds.
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
Originally Posted by katheikia' post='244990' date='Feb 23 2006, 05:53 PM
Found it. -32lbs for non Rfs. I wonder if that will change anything.
Ray Hull
Originally Posted by katheikia' post='244960' date='Feb 23 2006, 05:24 PM
Thanks
tundra
11-10-2016 06:55 AM
ucsbwsr
20
09-08-2015 08:30 AM
