Bridgestone Potenza RE050A RFT Pressure
My Ride: 2004 525i M Sport Automatic, M Sports Package, Bi-Xenons, Sunroof, Hot Climate Version, Navigation+TV, 18" Double Spoke 135M Alloys with Runflats, Anthracite Headliner, M Leather Steering Wheel. Through Load System, Hifi Loudspeaker System, Alu Cube Pure Interior Trim, Flashlight Cloth/Nappa Leather Sports Seats, M Sports Suspension
Dear Forummers,
I've done a search in the forums for the correct tyre pressure for the Bridgestone Potenza RE050A RFT tyre pressure. I wasn't able to find anything on the correct pressure. The tyre size is 245/40 R18 93W. Could anyone advise me on the correct tyre pressure in kPa or psi please? thanks.
Originally Posted by baadaaboo' post='448048' date='Jul 15 2007, 09:59 AM
because... it is written down on a label that you can see after you open the driver side door.
Originally Posted by 525imsport' post='448053' date='Jul 15 2007, 11:14 PM
saw that but don't understand what it says on that plaque on the door as everything's written in Japanese. This car was a UK Specification bought as an import from Japan.
My Ride: 06 530Xi w/ M-Sport Package
07 335i Cabriolet w/ M-Sport body kit
Where is your owner's manual?? Is it in Japanese too? Even so the pictures and the numbers indicating pressure figures should be the same.
If you see numbers like 2.6 and 2.9 that's the pressure in Bar (1 Bar=100kPa). Numbers like 37 and 42 are in PSI.
Just a thought.
ABC
Originally Posted by aybeesea' post='448312' date='Jul 16 2007, 03:27 AM
I assume there are diagrams of number of passengers, car orienatation, and the numbers (including tyre dimensions) are in arabic.
Just a thought.
ABC
Just a thought.
ABC
Originally Posted by 525imsport' post='448316' date='Jul 16 2007, 09:44 AM
Thanks aybeesea. Will check it out. Do RFT's require a higher pressure compared to non-RFT's of the same size?
Incidentally, I've looked at my "plaque" and it says for tyres of your dimensions:
Normal: F 2.2 R 2.5 (Bar) so 32 & 36 psi
Fully laden: F 2.7 R 3.1 (Bar) so 39 & 45 psi
ABC
Originally Posted by aybeesea' post='448318' date='Jul 16 2007, 03:55 AM
AFAIK no.
ABC
ABC
