Brakes
Old Mar 23, 2009 | 06:31 PM
v_therussian's Avatar
Question
Ok, so I heard a little brake "squeal" from my car today. I wonder, how trustworthy is the iDrive info for this? My iDrive is showing that I have 32k miles on front pads and 20k miles on the rears - I don't really trust it though... I'm wondering if I should just take it to the dealer and have the brakes looked at...
Old Mar 23, 2009 | 07:27 PM
Howitzer's Avatar
You have a long long way to go. BMW brakes squeak quite a bit sometimes and its normal.
Old Mar 23, 2009 | 07:30 PM
mikeg3tsguap's Avatar
Your i drive will let you know
Old Mar 23, 2009 | 07:38 PM
pinguhk's Avatar
My Ride: Mini Cooper
don't trust the idrive.
just look at the pads you will see the thickness of the pads.
my say 7000k and still have 80% of pads left.
Old Mar 23, 2009 | 07:46 PM
diggydrdre's Avatar
Talking
Yeah I wouldn't totally trust the idrive.
Visually check them.
Mine always squealed.
If you can change them early before the the warning comes you can get away without changing sensors.(I think)
I put some ATE pads in the front last month. They are good. Saved money, same pad just not in BMW box.
Old Mar 23, 2009 | 08:18 PM
pinguhk's Avatar
+1 I did not have to change my sensors
Old Mar 23, 2009 | 08:47 PM
MiamiPhill's Avatar
You'll know when the car can't stop.
Does it stop?
Old Mar 23, 2009 | 08:59 PM
BigMike's Avatar
My Ride: E60
Does it stop?
Hehehe! That was going to be my answer!
Seriously though, visual checking of brake pads would probably be the
best bet.
Old Mar 23, 2009 | 09:52 PM
best bet.
Ok, so if I visually check the pads, how much is too little? Or do I check the rotor for grooves?
And yes, the car stops... though I do gear-brake and coast to stops quite often, so it could be bc of something other than brakes LOL
Old Mar 24, 2009 | 06:41 PM
virgil's Avatar
My Ride: E60 530d M Sport, Alpine White, 2006, Australian
Model Year: 2005
How does iDrive know when you've changed the pads or disk rotors? Does it detect automatically or is there something that needs to be reset? If something needs to be reset, how do I reset it???
