Brake wear sensor warning and chime
My Ride: 2006 530i Sport Premium
WILL NOT RESET!
Yellow brake warning light
Yellow car on lift
Pads are fine
Checked and cleaned connections
Installed new sensors
Tried odo reset procedure at least 20 times
Odo reset attempt gives ---- then goes to 4500 on front brakes sometimes, other times just chimes and shows !
I know there has to be a way to reset this booger.
Yellow car on lift
Pads are fine
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Are you sure they are on right? The wear sensors reset themselves after driving a couple of miles if they are new. What type of car do you have?
Model Year: 05 530i
Engine: 3.0 M54
If you followed this procedure then you should be good. It took a few times for me to get it right every time I do it. Is this the way you are doing it.
Model Year: 05 530i
Engine: 3.0 M54
Could it be a bad sensor. Have you tried disconnecting the battery for 15 mins and then trying the reset? Just throwing some things out there I have never seen this issue before
My Ride: 535XI
Engine: N54
WILL NOT RESET!
Yellow car on lift
Pads are fine
Yellow car on lift
Pads are fine
I reset using carly.
