Brake Warning Light Reset
Old Jan 17, 2012 | 01:23 AM
C_o_s_m_i_n's Avatar
First remove the connector from the rear brake pads and try to reset like that. Range will decrease until -25.000.
Plug back the connector and reset.
If cannot reset, you need a new sensor, even if seems to be just fine.
Old Jan 17, 2012 | 01:27 AM
nevrev73's Avatar
My Ride: 2008 530d M sport
Originally Posted by Jeff E60
I reset the front one, but the rear one won't reset even though the pads are in great shape and the sensor is fine.
Are you telling me that even though the rear one was not tripped I have to replace it?
I had the same problem when i changed my rear ones on my E60... after around 20 goes it had to go intoBMW so that the could completely reset the brake system (electronically) as it would not reset at first even for them. I think after a certain amount of times that is what happens. You are doing everything right with the reset (just as I was) but it just wonbt do it.... Like everyone else on here has said, change the sensors but also if you have to, make sure that they are the original BMW sensor as the aftermarket ones can be a pain.
Old Jan 17, 2012 | 08:34 AM
Jeff E60's Avatar
My Ride: 2007 525 XI 1968 AMC AMX
I bought a full set of pads and sensors from BMW, but since the rears were only 20% worn I did not replace them.
I'll try unplugging the rear one this weekend and see if that works.
Thanks.
Old Jan 17, 2012 | 10:05 AM
This is the internal structure of a brake sensor.
You can see what happens if the strap is broken.
Honestly, it really doesn't matter if the sensor is OEM, or not. For example i rebuilt mine. And after reset it works just fine.
Attached Thumbnails Brake Warning Light Reset-bmw-e60-brakesensor-schematic.jpg
Old Jan 18, 2012 | 11:18 AM
RYNO311's Avatar
My Ride: 2007 Silver Grey 530 XI
Same issue here. When I access the rear brakes on the menu it asks for reset? and I push the button. It then populates with -15000. Anyone else see this?
Old Jan 18, 2012 | 11:44 AM
RYNO311's Avatar
Another quick question: ARe the brake sensors universal? Meaning is there a specific difference between the front and rear? I have one unused from the fronts I replaced last year...
Old Jan 18, 2012 | 12:49 PM
No difference between front and rear sensors.
Old Jan 19, 2012 | 10:09 AM
RYNO311's Avatar
Awesome. Thanks bro!
Old Jan 24, 2012 | 10:04 AM
Jeff E60's Avatar
Yes, this is what I got when it would not reset.
I unplugged the sensor and plugged it back it and it still would not reset.
Since I had a new one, I plugged it in and I was able to reset it.
I switched it back and it showed a lesser warning on the dash.
So I pulled the sensor off the brake pad and found this. So, I put the new one on.
Old Jan 24, 2012 | 10:06 AM
Jeff E60's Avatar
Electrically they may be the same, but mine were physically different. It had to do with the shape and length of the wire.
