Brake Sensor
Old Oct 31, 2006 | 06:29 PM
525iSE's Avatar
If you have a faulty brake sensor does that mean its not detecting brake pad wear correctly? Today a friend of mine says my squeaking is due to faulty brake sensor, I've also noticed that my brake wear on the iDrive have stopped decreasing for awhile now, is it because of the brake sensor. There's a possibility that my brake pad is completely gone but my iDrive didn't detect it!! Please help!!
Old Nov 1, 2006 | 12:47 AM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
There is a sensor that detects brake pad thickness? Wow
See your SA quick.
Old Nov 1, 2006 | 04:25 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I don't think there is a problem with the sensor doing it's job sensing the pad wear, I think the problem is simply a design flaw which causes the sensor to scrape against the rotor and make noise...
Old Nov 1, 2006 | 04:28 AM
colejl's Avatar
Indeed. Just had all my brakes replaced under warranty! (Were squealing like mad!)
Old Nov 1, 2006 | 10:33 AM
Laurencs's Avatar
My Ride: 2004 525i auto, PDC, Bluetooth, Sunroof, RFT, Towbar AND 2005 645ci Convertible auto, PDC, Bluetooth, RFT,Dynamic Drive, Active Steering, Adaptive headlights, Tv function, Navigation, CIP v23.02, Aux input, Logic7 Hi fi, CD changer, front seat heating and lumbar support, lights package, Style 121 19" tyres
My SA has confirmed that the brake squeal is due to a faulty design on the brake sensor that makes it scrape against the rotor.
They have told me I have to live with the noise until BMW redesign the brake sensor otherwise they will be changing the pads ever few thousand km's.
Personally I think their attitude stinks.... Why should I live with the noise?
Old Nov 1, 2006 | 10:35 AM
Veight's Avatar
Under warranty or the service plan?
Old Nov 1, 2006 | 11:16 AM
colejl's Avatar
Warranty.
colejl's Avatar
No - the part has be redesigned! And was fitted to mine under warranty!
Old Nov 1, 2006 | 11:21 AM
cobradav's Avatar
Sensor has been updated see SIB below:
SI B34 02 06
Brakes March 2006
Technical Service
This Service Information bulletin supersedes Service Measure B34 202 03 dated July 2003.
SUBJECT
Brake Squeals
MODEL
E60 (5 Series)
E61 (5 Series Sports Wagon)
E63 (6 Series Coupe)
E64 (6 Series Convertible)
SITUATION
Some customers may complain of a brake squeal noise during light brake application.
CAUSE
Wear sensor geometry (part of the sensor head protrudes beyond the edge of the brake disc).
Wear sensor material (the material combination of the wear sensor/brake disc can cause squealing noises under certain circumstances).
CORRECTION
In case of a customer complaint, install improved brake pad wear sensor. Improved wear sensor geometry and material have been implemented in 01/06.
PROCEDURE
Determine that the noise is not caused by random occurrence which can happen just before the brake pad wear limit is reached.
Replace the brake pad wear sensor and new brake pads only on the noisy axle.
PARTS INFORMATION
Part Number.................................. Description....................................... ..........Quantity
34 35 6 776 421......................Wear Sensor, Front E60/E61/E63/E64........................ 1
34 35 6 776 422......................Wear Sensor, Rear E60/E63/E64............................... 1
34 35 6 776 423......................Wear Sensor, Rear E61.............................................1
WARRANTY INFORMATION
For information only.
Old Nov 1, 2006 | 11:29 AM
AlexFW's Avatar
Model Year: 2005
Sure!
