hi to all, have a 525d msport 2005, just changed brake pads and front discs, however after 15 20 minutes of driving the brakes squeek like mad very loud just before the car is about to stop, can anyone give me some answers regarding this problem, thanks.
welcome. the brakes squeaking is a common problem. i myself had my front brake pads and rotors replaced at about 22k miles and they did it under waranty. here's a past thread that i found about it when searching: http://forums.e60.net/index.php?showtopic=...s+noise+squeaky http://forums.e60.net/index.php?showtopic=43841&hl= . hope this helps. enjoy the forums.
thanks mate, great help, new here and will be posting pics of my 5 soon, thanks again.
Did you change the brake pads yourself or did the dealer?
i have an 08 535i maybe 4000 miles on it and my brakes squeak also,only when my windows are down and i press light on the brakes can i hear a noise. do you think its just brake dust or is there something wrong? thanks
Originally Posted by Rudy' post='462405' date='Aug 25 2007, 10:28 AM
What you describe sounds more like the wear sensor issue from earlier model year cars but on your 2008, you'd think it would be fixed by now...
Originally Posted by vandal1x' post='462407' date='Aug 25 2007, 11:35 AM
im sorry what do you mean by wear sensor? why would a sensor make noise? it doesnt do it all the time just every once in awhile but then again i dont drive with my windows down all the time. thnaks
http://forums.e60.net/index.php?showtopic=23492 Now if the brakes only squeal when the windows are down (not when they're up) then dude, you're on your own! ;) |
Originally Posted by Rudy' post='462412' date='Aug 25 2007, 10:56 AM
Well I'm assuming that the brakes still make noise even if the windows are up (you just don't hear them, right?) so if that's the case, it sounds a lot like this issue:
