brake dust - the grime that steels my shine
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
My Ride: 2008 535i / Black Sapphire / Premium / Navigation / Bluetooth / PDC / USB Audio Integration / 6 Speed Sport Automatic with Steptronic / Logic 7 / Comfort Access / Auto Folding Mirrors / Comfort Seats / Rear Heated Seats / 35% Tint All Around / Black Dakota Leather
I have the same problem. The only thing that will work permanently is AXXIS brake pads.
Let me know if you find a spray or solution that works for now. I need one just as bad as you do.
geez i think you need that heavy duty stuff that they used to clean my wheels before they repaired them.. but not strong enough to ruin your powdercoat... i wonder if you can clay them to get the grit off (of course throwing out the clay afterwords)
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Let me know if you find a spray or solution that works for now. I need one just as bad as you do.![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
The easiest and probably most effective is brake cleaner. It will desolve the brake dust. HOWEVER, not sure if it is safe for powder coat. I think it would be as powder coating is pretty tough and not a paint. You would have to check with a someone who does powder coating to make sure.
If this is not an option, I would to try a cleaner/polish that is safe for clear coat that you would use on your paint. Something that has some abrasive to it. Mothers makes a pre-wax cleaner that might be worth a try or rubbing compound until you get down to the powder coat.
My Ride: 545i Sport
Engine: N62
![](http://kfvs12.images.worldnow.com/images/5089331_BG1.jpg)
Try Mr. Clean? Magic Eraser.
I clean the inner barrels of my wheels once a year when I change to snow tires. First I use wheel cleaner and rinse thoroughly but to get all the grime off I use Gumout carburetor cleaner. It?s the only thing that cuts through the grime/tar/brake dust but I make sure it doesn't get on the front part of the wheels.
bestofthebest
03-28-2016 02:47 PM
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
