brain fart; drove 80 freeway miles in DS mode
Most everyone says that DS won't go into 6th gear. Mine won't. I have a 2005 with software updated in May. I think it is 16 - perspective Nav etc.
Everyonce in a while, someone says different. Usually it turns out that they were wrong. But who am I to say. If while cruising along, there is no difference between D and DS, then maybe a newer upgrade goes into 6th gear. But for most of us, it does not.
Mine does not go into 6th, at least not up to 100 MPH. That is about 4000 RPM. 4000 RPM in 6th would get me 125+
Model Year: 2005
Engine: 545i
I can assure you - 6th is locked out in DS on my car. Theoretically, it would go into 6th after the rpm limit would be reached in 5th. Do the math.
Software 19.01
Software 19.01
My Ride: 528i
Model Year: 2011
At highway speeds moving the shift lever from D to DS has no effect on engine revs. Its in 6th gear. Maybe its different with the V8 cars.
Originally Posted by Taz' post='202057' date='Nov 22 2005, 01:10 PM
Perhaps a dumb question! How do you know which gear you are in when in 'D' or 'DS' mode? I have a 2004 E60 and cannot get it to tell me which gear it is in. Do you just go by the revs versus the speed to figure out the gear you are in?
My Ride: E61 530d Touring, May 2004
I've certainly never found 6th in DS on my May 04 530d.
I do often go D -> DS -> M6 at motorway speeds to hold in 6th (runs smoother in gentle cruise control, using the torque rather than kickdown). From the rev counter can see it always changes down to 5th when go to DS
So, I can get to M6 in DS or D mode.
My Ride: 2015 535D M Sport
[/quote]
Once you manually shift it, you are no longer in DS mode, you are in manual mode. They aren't the same thing. Look it up in your owners manual.
My Ride: 2006 525i, Alpine White, auto, premium package, nav, cold weather package, euro red reflectors
[/quote]
In my 06 525, my display (next to the speedometer) reads either D, DS, or M1, M2, etc.
In my old 530 (e60) when i bought it in 2003 the DS and D modes shifted to 6th gear, then I complained about I drive and the dealer reprogrammed the I drive and they say the transmision programs got updated too. Aftwr that the DS mode did not engaged 6th unless I was over 100mph, I complaint and complaint to my dealer shop foreman, after a lot of research of him (supposedly) and a few weeks I went back . They re-reprogrammed the car again and WOALA fixed, DS shifts to 6th gear. I can notice by moving the lever from DS to D and rpms not changing. My new 550 has not had any software upgrades and does the same in DS or D (no changes in rpm)..just the DS is more aggresive and sensitive to the gas pedal and downshifts faster.. be a good idea to complaint to your local shopforeman...
