BMW's Spare tire set - getting away from Run-flats
My Ride: 2005 545i | Titanium Silver | Sport, Premium, Cold Weather, Navigation packages | Style 124 staggered rims | iPod integration | Tinted windows
Hi Guys, Can you please offer some suggestions here?
I have finally decided to ditch my OEM run flats. I currently run OEM Dunlop SP Sport run flats on 124 rims on my 2005 545i sport package.
I'm looking at upgrading to 19" staggered VMR's - although I can't seem to decide between their V710, VB3 or V718's - but that decision is for a different day.
My concern is that I will need a spare tire kit once I ditch the run flats. BMW has an Emergency Wheel with Tire set # 36 11 0 308 889 that should fit in my truck perfectly. Can you confirm that I have the correct part # for my 2005 545i? Here is the kicker - Canadian price from BMW for that Emergency Wheel set is $601.13 + taxes! Wow, isn't that just crazy? I'm sure I have seen spare tire sets sold on this forum for approximately $200.
That said, does anyone know where I can get this cheaper? I do have a shipping address in the US, so I can purchase from the US instead of Canada. I know that Gary of Newport used to give us a 25% discount, but not sure if that is still valid. Did someone here also have a contact at Tisher BMW?
Also, I can go with a Mobility kit, part # 71100415041 which is essentially a compressor and a tire sealant. Price is approx $130 US. Do you recommend this instead of the spare tire?
Here is another issue my dealer mentioned. If I do have an issue and call BMW's road-side assistance, they may not provide any support (towing) if I don't have the original equipment installed, ie run-flats. I know I qualify for up to 50 km's of free towing with BMW Assist, but apparently that would be void if I swap to non-run flats!
Lastly, concerning my 2005 545i, I heard that the Canadian models in 2005 did not include TPMS sensors. Do you know if that is true? I know I have a Flat Tire Monitor (FTM) section on my iDrive??? I also know that the system was different on pre-LCI cars. So, wondering if I need to purchase TPMS sensors with my new rims?
Thanks for your help here!
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
On the FTM/TPMS, you are correct that you do not need sensors. The direct (sensor-based) TPMS was introduced in 2007 (still pre-LCI) but as you indicate - you have FTM. You can confirm with more certainty by examining the tire valve stems - if they're black plastic, no sensor; if they're metal, you have sensors (TMPS) although I highly doubt this will be the case.
Good luck with your tire choice!
______________________________
2008 550i M-sport
2006 X3 2.5i
BMW's road side assistance will not give you grief for having non-OEM tires. I've used BMW Assist with my X3 with non-original rims/tires and they still provided normal service. If you were still under warranty, you might encounter an issue if your non-OEM part can be blamed for damage... but that shouldn't be an issue for you given the age of your E60.
2008 550i M-sport
2006 X3 2.5i
2008 550i M-sport
2006 X3 2.5i
Wpg550,
Thanks for your reply! I'll check my valve stems to confirm, but I'm quite certain that they are black plastic / rubber so they probably do not have TPMS sensors.
My Ride: 2006 BMW 550i
i thought all e60 except m5 had spares
so you dont have anything where the spare is supposed to be?
does that part# you mention include the wheel, jack, lug wrench, tire chock, and the foam inserts?
Yes, from what I understand, that part # is supposed to include the jack, wrench, etc. It's a full kit. But, can't justify $601.13 Canadian!!!
My 2004 545i sport came with Dunlop runflats on staggered 124's and the spare tire kit in the trunk. Don't know if this is a USA region thing or not. The spare actually came in handy when I picked up a screw in one tire, and put on the spare while having the screw puncture repaired. I did not drive on the spare, it simply meant I did not have to leave the car up on the jack while the main wheel was off being repaired.
+1 I also have the spare in my Sport Package equiped 545.
Wow, that must mean that only Canadian cars came without the spare tire kit. And our cars cost more than the US models!
I guess we got ripped off!
