BMW Style 128's for e60
Most importantly is the awd version less concave?
I read somewhere that stagerd rims are acceptable as long as the tires are different to allow similar wheel rotation I've seen people recommend 235/35/19 (19x8.5) front and 265/30/19 (19x10) rear
xi cars need an offset of 35-40mm. Due to the higher offset, they are much less concave.
I choose to run 19x8.5 with 245/40 square set up on my 535xi. There is no rubbing.
You can run a staggered set up on xdrive and you are correct in that the total tire diameter needs to be very similar.
TroyE60
05-30-2019 05:01 PM
bestofthebest
03-30-2015 08:12 PM
