BMW Genuine Auxiliary Audio Input Cable For E60
http://www.amazon.com/BMW-Genuine-Au...7472599&sr=8-1
Is this all I need to play an I-pod? My car does read MP3's and does not have nav.
i have a aux plug in the back wrest under the my arm while I'm driving. and there is aux option on the screen.
does this i need the direct cable from my iPod to the aux only?
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Well, if you have all the Jack and Aux shows up in the menu then this is the cable you need!
http://cgi.ebay.com/ebaymotors/BMW-s...#ht_598wt_1165
The software is in the DIY forum.
http://www.amazon.co...17472599&sr=8-1
1) you will need to change your vehicle order to have +NAUX if you do not have Aux option in your idrive. Look to spend about $300 or so to do this plus the cost of the cable which, that price you have is way too high. .... should be about $45 and is a shit cable which you'll probably have to cut apart to take out the resistors to get decent sound.
2) I could code it for you if you have the OBD cable.
3) If you did by the cable above and install youself, You'll have to take the pins/cables out of the X183 plug and insert them into your own. Sucks for something you pay for.
You need a male to male 3.5mm jack to plug into the audio output and into your phone. You will not be able to control iPod/phone from iDrive.
I think you can buy a cable on Ebay and program it yourself:
http://cgi.ebay.com/...e#ht_598wt_1165
http://cgi.ebay.com/ebaymotors/BMW-U...ht_7401wt_1165
TroyE60
05-30-2019 05:01 PM
