bmw E60 N52B25 -VANOS Problem?
Old 12-24-2014, 11:16 PM
  #21
bota's Avatar
Originally Posted by twh
Thanks,
I have seen this procedure.
so when it say:
...If excessive wear to the camshaft bearing ledge is found, it is only necessary to
replace the camshaft hook ring seals and the affected camshaft bearing ledge.
N51, N52 and N52K intake camshaft bearing ledges and hook ring seals cannot
be replaced separately. Cylinder head replacement requires a TeileClearing
PuMA case
...it means the head should be replaced.
What is TeileClearing PuMA case?
At the end this looks like plenty of $$$$$
Old 12-25-2014, 05:22 AM
  #22
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
If it is the exhaust bering ledge, that part is replaceable. It will still be a big job, but you don't need to remove the cylinder head. If it is the intake bearing ledge, that is part of the cylinder head casting and can only be fixed by replacing the head.
Old 12-25-2014, 05:25 AM
  #23
twh
twh's Avatar
Engine: N52
I would first: change the oil, make sure the oil filter cap is assembled correctly, put in new vanos solenoids (about $125 each). Then monitor the situation for next steps -- hopefully you don't have any
Old 12-25-2014, 11:39 PM
  #24
bota's Avatar
Thanks a lot!
Old 02-17-2015, 11:56 PM
  #25
bota's Avatar
Does anybody know what would be if the connectors(plugs) for vanos solenoids are accidentally replaced?!
Does anybody have a picture of correct position of the connectors for N52B25 in E60?
Thanks
Old 02-18-2015, 12:29 AM
  #26
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
Go to line #17:
https://5series.net/forums/e60-discu...-137647/page2/
Thanks
Old 02-27-2015, 04:19 AM
  #27
bota's Avatar
Thanks
Just as an update,
it came up that the connectors had twisted position...which resulted in strange idle after start which stabilize in next 3-5 minutes. while in driving no change ?! Strange, isn't it?
SFx550i
04-14-2015 05:00 PM
joeekrub
03-25-2015 07:00 AM
BYS2
03-24-2015 03:13 AM
mybeemer
03-17-2015 02:45 PM
bananfiu
03-14-2015 02:08 PM
Quick Reply: bmw E60 N52B25 -VANOS Problem?
