Bmw e60 a/c expansion valve how to locate
Old Jul 8, 2020 | 04:36 AM
Bmw4u's Avatar
My Ride: E 60 5 series BMW
Engine: N52
Default Bmw e60 a/c expansion valve how to locate
E 60 525 i a/c replacement of expansion valve
When I bought the car was already with a/c leak , that was re filled with FREON JUST TO BE SELL,
now " is my problem,"
who knows for how long they were doing that, all air inside the system, may or may not mess up
FOLLOWING THE HIGH AND LOW LINES TO THE FIREWALL, I CAN NOT SEE THE EXPANSION VALVE,
any knowledge will be very help full, thank you in advance
Old Jul 8, 2020 | 04:51 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I think you have to locate it in the passenger footwell. It should be sitting on the side of the evaporator core.
Old Jul 8, 2020 | 05:17 AM
Bmw4u's Avatar
Engine: N52
Thank you for your time,
but the expansion valve are (yes like you on the side of the evaporator ) that is located rigth in the middle of the dashboard, expansion valve, goes from the evaporaror low and high port lines to the ones are coming from engine,
not the footwell maybe the ac drain line is there, but is not cause i looking for that too.
dammed these cars men, nothing is parked at the drive way for 12 days,
Old Jul 8, 2020 | 10:55 AM
I was just stating it was on the passenger side footwell. It's not hard to get to. I have done the blower motor before and it took 3hrs for complete assembly. The valve is easier to get to. You should be able to get to it when the glovebox is taken out and you take the screws out on the engine side
Old Jul 8, 2020 | 11:43 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Here is the procedure for R&R of tev on IHKA system. Valve is accessed from passengers firewall after removal of fresh air boxes.
https://www.newtis.info/tisv2/a/en/e...ements/PRw49jp
Old Jul 8, 2020 | 02:00 PM
Bmw4u's Avatar
Engine: N52
THANK YOU THANK YOU THANK YOU !!!!!!!!!!!!
,I never work on these car before, is my first and i got so screw with the a/c sistem is not good. And p0004 , he lie to me in everything,
the rubber grommets mislead me, now I know taking out the way i have access, i already took the air filter and housing, it have to be in these area.
If you know ,please I have another post here because also notice was water in the footwell, the drain from the a/c how to access to put some air compress or a least be sure is not clogged, cause is my fault so frustrated about the a/c,
i did not look if water is drained good , i can not use the car , all is out should be a good NOW to be sure is NOT CLOOGED,
thank you again , i can not wait to drive the car again
Old Aug 12, 2021 | 06:08 PM
embarine's Avatar
Probation Members
My Ride: 2005 530i
Does anyone have a link to the instructions? The link is no longer working...
Old Aug 12, 2021 | 08:08 PM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Why do you need to get to the expansion valve? Is the leak there and how do you know that it is there?
Old Aug 17, 2021 | 09:13 AM
plus1111's Avatar
My Ride: 535xi
The AC in my '06 530xi never worked well. I figured out the system had been open for a while before I got it. I replaced the drier cartridge that is in the condenser in front of the radiator, vacuumed it down a few hours and recharged. It works fine now..
Bmw4u
Jul 5, 2020 09:31 AM
ukr
Feb 19, 2020 04:57 PM
JBasco20
Nov 17, 2017 04:54 PM
jlshand
Jan 23, 2012 12:51 PM
khooger
Aug 4, 2009 04:42 PM
