BMW E60 545i Transmission leaking
Old Jun 25, 2012 | 05:25 AM
Ammar545i's Avatar
My Ride: 04 545i Sapphire black -18' M5 wheels -Sport pack -LED Angel's
I notice a dime size spot of fluid every morning and I have already bought the pan gasket and Pentosin ATF. Can you guys help me with a step by step diy?
Thanks
Old Jun 25, 2012 | 10:04 AM
pcy's Avatar
pcy
use a flashlight and make sure you understand where the leak is actually coming from. Mechatronics sleeve is known to leak... it leaks along the pan wall and on to the gasket... leading you to think the pan gasket is actually leaking.
Old Jun 25, 2012 | 01:36 PM
rrnag30's Avatar
My Ride: 05' 545i
+1 well documented Mecha. issues with this model.
Old Jun 27, 2012 | 11:37 AM
BimmerFan52's Avatar
+1
Definitely requires diagnosis before you begin to tear it apart.
My 545i required both pan (cracked) and mechatronic sealing sleeve replacement at 74K miles.
You will use your gasket in any case, but you'd hate to have to do it twice if the gasket is not the source of the leak, necessitating buying more fluid, another gasket and spending even more fun time under the car.
http://www.thectsc.com/index.php?p=p...e_id=tech_info
Old Sep 2, 2012 | 10:53 AM
Kaizen's Avatar
My Ride: 2005 545i Alpine White Premium package, Sport package, Nav, HUD, PDC
Sorry to revive an old thread, but I just took my car in for an oil change and the battery cable recall and my service agent noted that the mechatronic sealing sleeve needs to be replaced. I was quoted $920 parts and labor from stealership. Does this sound on par as far as pricing goes?
Old Sep 2, 2012 | 12:03 PM
deansimpson's Avatar
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint. Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels. Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
They all seem to need the megatronic sleeve replaced at some point.
I had to mine at about 53,000.
Cost $500 at an indy trans shop.
Don't go to the dealer!!
Here's another tread with some good info.
https://5series.net/forums/topic/123...leeve-leaking/
Old Sep 2, 2012 | 06:00 PM
Kaizen's Avatar
Thanks Dean. I appreciate the reply and link.
Old Sep 29, 2012 | 03:51 PM
jc545's Avatar
the sleeve its self ive read is only about 15-20 dollars so thats somthing to consider
BLACK_PRINCE54915
May 8, 2019 02:45 AM
BMW565
Nov 6, 2017 06:03 PM
BYS2
Mar 24, 2015 03:13 AM
Mihainede85
Mar 11, 2015 09:45 PM
SURYOYO
Sep 30, 2003 02:20 PM
