Bmw E60 2006 550i
Old 07-29-2019 | 06:37 AM
audiophool's Avatar
My Ride: 535xi
Originally Posted by boostjunkie
visualy and i tried rotating them for any play they seem tight no slack or clunking i jacked up one side pit it in neutral and let the e brake off and i can rotate thdrivers side rear but not easily and it seems to jam and require alot if force to unjam the rotates a bit almost freely then jams again fluid was done at 120,000ks at 150,000ks now
If it jams while turning the wheel, can you hear any sounds? Assuming the car is safely supported, go under and listen at the CV joints and at the diffy case to see if you can narrow down the location. If not, I'd be pulling the CV shaft out for inspection. After it's out, rotate the wheel again to see if it's all smooth. Then turn the diff with the axle stub to see if the jamming can be re-created.
Old 07-29-2019 | 11:45 AM
boostjunkie's Avatar
My Ride: 2006 bmw e60 550i msport
i believe its the diff after the oil sat overnight i drained the tray the next day and the bottom of the tray is full of metal filings nothing large but a definite diff issue, anybody used any lsd upgrades etc or no what models would have the same diff or the internals the same?
also anybody done bearings in there n62?
Old 07-29-2019 | 11:48 AM
Old 07-29-2019 | 09:31 PM
audiophool's Avatar
My Ride: 535xi
Time to take the cover off...
kane1111
04-10-2015 05:40 PM
kane1111
11-17-2014 10:59 PM
schanE60
Detailing Forum
16
05-31-2009 12:31 PM
omszz
08-12-2008 02:06 PM
Juan G
05-21-2005 11:44 PM
Quick Reply: Bmw E60 2006 550i
