BMW E60 2004 Battery Charge at 50%
Dear Contributors,
I have a BMW E60 2004, the battery died few months ago and replaced with Bosch S5 100 A battery, the battery charge has been always at 50% (in ISTA battery test), i did all the necessary battery registration, and configuration, i did replace the IBS and the Alternator to test, went through software updates for the whole car, but still the battery would not go up more than 50% in ISTA Battery Charge state
I tested another battery, a used Bosch S3, and the battery charge over 5 days went up to 80%, and I'm really confused, I tried to replace the new S5 battery with another similar one and battery charge remained over 5 days at 50%
I did an extensive test for any power leak, but nothing in this area
Any thoughts? I did a lot of reading on this but no luck so far in getting this resolved
Appreciate the advice
Regards,
Abed
Regards,
Abed
Since I tried another battery and the charge state went up to 80%, I'm guessing the Bosch S5 is not as strong as it should be as I also tested another S5 battery and same result
So maybe the Bosch S5 batteries are not compatible with our cars
Can other confirm?
Thanks
Abed
Can other confirm?
Thanks
Abed
Awest91
09-17-2022 11:05 PM
Mihainede85
03-11-2015 09:45 PM
