Bmw 545i fuel consumption problem
Old 11-21-2012 | 09:00 PM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
Rafi, a good place to start is getting a baseline so you know what you are dealing with. This would be a compression check. Although probably fine, this will let you know if you have small of big issues.
Secondly have the multiplicative (long term) fuel trim read and report the number. If it is high then you have an issue with one or more fuel/emissions components providing the previous doesn't show low compression.
You will also want to pull out at least one plug and look at the end. If it looks black and fouled then you know it is running rich. If it is white then it is running lean. Somewhere in the middle is normal. There are plenty of sites that tell you how to read a sparkplug.
Lastly run a bottle of Techron or Redline fuel system cleaner through. The only 2 additives that i have ever seen actually work. Verified by my video scope!
I was getting 12-13 in the city in D, 8-9 in DS. My long term fuel trim was at 12. Way too high. I replaced my MAF and the mileage immediately went up to about 15.5. I then replaced my pre-cat o2 sensors and the mileage leveled off at about 16.5 city only. After 2 weeks i checked my long term fuel trim and was at 1. Now that is better!
Old 09-06-2013 | 08:15 AM
ivogeorge's Avatar
My Ride: E60
Hi guys, any updates on this issue? I just bought 545i last week and I am experiencing the same issue. More than normal fuel consumption but also the throttle is jumping up and down. I am thinking maybe the air flow meter?
Cheers
Old 09-08-2013 | 03:26 PM
MarkieMarkH's Avatar
My Ride: Looking!
Check the following: 1) Is the air filter clean?, 2) Is there any restriction in the exhaust/catalytic converters (place hand near exhaust - If feels weak use an IR thermometer to check heat levels after the cats. Should be nice and high. If cool, that converter is likely blocked), 3) Do spark plugs if over 50K miles and 4) Check for 02 sensor error codes. Obviously there are more things to consider, but these things should all be checked first.
Old 09-09-2013 | 03:25 AM
ivogeorge's Avatar
My Ride: E60
Thanks!
What I did so far:
Day one:
Checked the air filter and it was DIRTY, so cleaned it up and ordered a new one.
Cleaned the sensor from the Air Flow Meter with a Contact spray.
Result - All was the same
Day two:
Put one bottle of STP's injector cleaner on 1/4 of the tank and after running almost empty tank put some 15L of fuel and one bottle of STP's petrol-line cleaner.
Manage to find CRC's Air Flow Meter Cleaner and cleaned the sensor, for the second time.
Result - Idle still ruff but lowered consumption from 13.6 to 9 L per 100 on 136km/h.
Any thoughts?
Cheers
Old 09-09-2013 | 06:25 AM
My Ride: Looking!
Originally Posted by ivogeorge
Thanks!
What I did so far:
Day one:
Day two:
Any thoughts?
Cheers
I notice that you said you were at 84 kilometers, which converts to about 56,000 miles. I'm pretty sure that your car is wanting new spark plugs...
Old 11-06-2013 | 05:25 AM
ivogeorge's Avatar
My Ride: E60
Default Update
just changed the throttle actuator, consumption now is as it is suppose to be, normal. Total cost around 450 fr.
Old 11-06-2013 | 02:48 PM
545iMike's Avatar
My Ride: 545i
Did changing the throttle body fix your jumping idle?
Old 11-10-2013 | 11:41 PM
ivogeorge's Avatar
My Ride: E60
Yes! and at the same time put the consumption in order
Cheers
JonathonK
03-27-2015 08:13 AM
coops
10-07-2003 04:45 AM
SURYOYO
09-30-2003 02:20 PM
Thomas the Swede
09-13-2003 12:22 PM
08-12-2003 11:41 AM
Quick Reply: Bmw 545i fuel consumption problem
