Blinking green led for headlight switch
might wanna see if there's some other fix. my headlight switch light actually stayed on and active steering was active last night. but inactive again tonight. so it's turning on and off for some reason. just saying.
My Ride: 2004 545 6 M/T
2004 545i with AHL.
Has anyone ever heard of the LED flashing light by the headlight switch BECAUSE the fog light bulbs were replaced with different wattage (80 vs 51) or anything else concerning the fog lights?
My LED just stated flashing... although I cannot recall if it started flashing when I replaced the fog light bulbs.
Thanks!
Thanks!
help plz I just spend 2,800 on a brand new headlight assembly for both sides of my 04. 545i an my eyebrows still won’t come on DMV WONT PASS ME FOR THE LEDS (eyebrows) also I have a flashing green light on my switch inside the car….. this light was flashing before I had the new oem headlights and is still flashing after installing the brand new ones I’m so upset I could SCREAMMMMM someone said they replace the fuse for this problem? Where was it located glacé box or under hood ? Pics would be a great help! Thanks guys
Engine: 3.0 B58; 3.0 M54
They should of gave you their error message before changing the headlights. Most of the time it's your LCM under the glove compartment that needs to be replaced and coded. Do you know the code it's giving you? That is the first step
umnitza
Nov 3, 2015 02:58 PM
525i_owner
19
Oct 12, 2015 11:00 AM
