Black i drive
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
My i drive screen is black or only showing BMW logo.
I think there is a procedure to reset the sowtware (CD eject + DVD eject + mute). But I don't have any "mute" button on my board ... what's the procedure then ??
However, my similar situation ONLY reguired a reload of the software
SI B 84 08 05
Phone, Navigation Systems March 2006
Technical Service
This Service Information bulletin supersedes S.I. B84 08 05 dated January 2006.
(New) designates changes to this revision
SUBJECT
CCC - CID Switches Between BMW Banner and Blank Screen
MODEL
E90, E91 (3 Series) with SA 609 Car Communication Computer (CCC)
E60, E61 (5 Series) with SA 609 Car Communication Computer (CCC)
E63, E64 (6 Series)
SITUATION
The customer may complain that the Central Information Display (CID) switches between the BMW banner and a blank screen (resets). One of the following fault codes is stored:
(New) CID FC "A468 LVDS cable break"
CCC-BO FC "A3E4 fault in file system"
CAUSE
CCC Failure
(New) PROCEDURE 1 (CID FC A468)
On a customer complaint basis, submit a PuMA case to the Electrical Group along with FASTA data.
PROCEDURE 2 (CCC-BO FC A3E4)
(New) In order for this procedure to work properly, DIS V44 and Online Update "DIS_UPDATE_12.4_"or DIS V45 must be installed on the DIS/GT1.
This procedure will only work if "CCC-BO FC A3E4 fault in flash file system" is stored. Do not clear the fault.
Perform a short test on the vehicle. If the CCC-BO is not recognized during the short test, perform an individual test on the module. The CCC may be resetting at the moment.
Page right and identify if "CCC-BO A3E4" is shown in the listing of faults. Switch to "Control unit functions" and select CCC-BO.
Page right and select DIS test plan "CCC complete B6512_50013"
Continue in the test plan until the screen "under fault evaluation A3E4 Control-module fault in CCC. Resetting CCC." At this point the flash file system is being corrected. It will take about 15 seconds to finish
On the next screen the following results are given "A3E4 Control module fault in CCC. Procedure: reprogram CCC (CCC-BO, CCC-ASK, CCC-A, CCC-ANT, CCC-GW)." Make a note of the GWCODE (warranty code) for vehicle programming in the comment box of the warranty claim.
Verify that the flash file error is corrected by ensuring the CID is shown on the BMW Banner and is not cycling. One reset may occur after the test plan has finished. After 3 minutes the system should be stable and not reset.
(New) Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman V21.00.00 (Target Data Status E060-06-03-510, E89x-06-03-510) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
I had the exact same problem as you. I tried everything but in the end had to take it into the delaership for a software upgrade. It took about two days for them to be done.
My Ride: E61 525i SE Touring Automatic - Titanium Grey II, Auburn-Dakota Leather, 17" Light Alloy Wheels Star-Spoke Styling 138, Anthracite Headlining, Maple Wood, Electric Front Seats, Front Seat Heating, Automatic Air Conditioning Advanced, Navigation System Professional, Bluetooth phone prep, Professional radio, Hi-Fi Loudspeaker system, Park Distance Control, Rear Side Airbags, Side Blinds
Had the same problem.
I took the car back to the dealer who reloaded the software (approx. 6 hours of work).
Issue didn't come back afterwards (2 months ago).
Reset didn't arrange my i drive problem.
My car is at the dealer's workshop for the night. They say it's not the 1St E60 to suffer this problem. They launched an upgrade of the software (V.24). It's supposed to last 5 hours ! Normaly I can get my 53OD back tomorrow morning. I hope it'll be ok, because I need all the functions of the i drive to go to Le Mans next Friday (DTM races !)
I am in the exact position, I contacted the dealer and will take mine Wednesday. i-Drive crash is very common on the E60 according to my dealer too, I just hope it is not a recurring issue
I hope you get your car on time.
Keep us posted
My Ride: E61 530d Touring, May 2004
Mine has gone blank then rebooted itself whislt driving twice in the past 6 weeks. Not a big deal (except the loos of nav at short notice on a dark unfamiliar road).
The dealer can't find any error code, but proposes to do a software upgrade. Hope this doesn't make things worse (UK May 2004 530d)
Got my car back this morning.
Everything seems to be OK now.
They upgraded to V24. There are some big changes in the screens.
Menu is different, more convivial I think.
I've still to try all functions to discover all new things.
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Originally Posted by OliverB' post='343499' date='Oct 10 2006, 03:04 PM
Got back my car this morning.
I've still to try all functions to discover all new things.![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
I am taking mine tomorrow and I hope they upgrade the software too.
let us know about the new features.
TexaZ3
05-06-2015 09:54 AM
srogers535x
14
04-26-2015 09:39 AM
