Bimmer won't start need our forum gurus...
Old 11-09-2014, 02:54 PM
yanik's Avatar
My Ride: 2006 e61
Still no start with old battery back in. It won't start with IBS connected or disconnected.
Read out from second battery test after charge:
Voltage: 12.81V
Measured: 931CCA
Temp: 71F
There is also a really long humming maybe 5 to 10 seconds long when I try to start. After a few seconds the Foot Pedal Start Icon pops up. Could the key have un-programmed itself and maybe that is the cause?
Old 11-09-2014, 02:55 PM
yanik's Avatar
My Ride: 2006 e61
HA! Why would the battery still be tested as a good battery???
Old 11-09-2014, 03:01 PM
yanik's Avatar
My Ride: 2006 e61
Slight edit on the year of the battery.. I saw a 06 somewhere on there and thought it was original... Its MFD Stamp Date is May 2010...
Old 11-09-2014, 07:53 PM
H F
H F's Avatar
My Ride: 2005 545
If the battery has 12 volts is enough to crank the starter .
If it was me I would get a light tester and check the solenoid wire , and see if it's getting power from the ignition,, if that checks out good Then run straight power to the solenoid and see if it turns the engine .
Old 11-09-2014, 09:10 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
battery can read 12v but still have a bad cell.
Old 11-10-2014, 04:07 AM
sanjsanj's Avatar
My Ride: E60 530d
but you'd still get some noise from the starter, or clicks at least.
Get some power to the starter and see if it works
Old 11-10-2014, 05:02 AM
yanik's Avatar
My Ride: 2006 e61
Default My fault codes using BMWhat
Anything here that would help answer the question!?
Fault Report - BMWhat - Version: 14.01
ID1: da161258-811e-413f-83ae-0e303a1c70d1-854ID2: 5a90673e-4bc5-4182-b3e8-40794a2568ed-c1a-2a5207b8b3a2df
III:none I
INFO: USB-MODE
Base: E60 E61
Faults: 13
ECUs: 31
Model: 530 xi N 52 B 30 A
Battery: no battery info
Normal communication
Normal connection
Normal Comm-Speed
C 2
Date: 2014-11-09 21:32:01
USB Device
Version: 17
Device: >iNet< >polaris_inet< >A727<
Motor Control:
Engine / Motor
Fehler: Message (air conditioning demand) / Message Error PT CAN / message fault code
Code: CDA9
Fehler: IBS Communications / Plausibilitycheck for DFP_CAT- / Intelligent battery sensor, communication
Code: 2E8E
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Fehler: :Clutch is in the open position - rear wheel drive - Transfer Ec / Transfer case / Transmission ECU Failure
Code: 5F3A
Fehler: Steering angle sensor
Code: 5EBA
Airbag:
Advanced Crash and Safety Management (ACSM)
Fehler: B + line / Recognized under tension clamp30
Code: 93FC
Satellite front left door / Tuer vorne links
ECU OK, no Fault Code
Satellite front right door / Tuer vorne rechts
Satellite center / Mitte
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
Instrument cluster:
Instrument cluster / Kombiinstrument
Fehler: Debug Info Combi
Code: A557
Fehler: Air suspension failure
Code: A3C7
Central info display / Zentrales Display
Light/Rain Control:
Rain/light sensor / Regen-Lichtsensor RLS
Fehler: sorry, unknown fault
Code: DA44
Light / Licht
Fehler: Deep Discharge Battery protection / Short circuit failure 3
Code: 9CBA
Fehler: Battery cut-off relay
Code: 9CC3
Heating / AC:
Air conditioning / Klimaanlage
Immobilizer System:
CAS
Park distance control:
Cruise Control:
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Phone / Telefon
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Steering column switch / Lenkstockschalter
Fuel pump / Kraftstoffpumpe
Power Module
Car Communication Computer CCC
MASK
Center-Konsole
Fehler: Steering column module: initialized position data
Code: 9FED
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Fehler: Fault in the battery
Code: 9D12
Chassis:
Air suspension / Luftfederung
Central Control / Zentrale Bedieneinheit
Body:
Car Body Module
Fehler: KBM under voltage
Code: A409
Tailgate / Hecktuer
Other:
Old 11-10-2014, 05:45 AM
yanik's Avatar
My Ride: 2006 e61
Code: 9CBA
Code: 9CC3
Code: 9D12
Code: A409
Found these faults in the list that r battery related... Sounds like the battery is still the cause!? Can anyone chime in?
Old 11-10-2014, 06:44 AM
pcy
pcy's Avatar
Take the battery out of the car, take it to an auto parts store and have them LOAD TEST the battery. That will tell the health of the battery.
Old 11-10-2014, 07:10 AM
yanik's Avatar
My Ride: 2006 e61
PCY - they did that when i brought it there and I was told it was a good battery....
Im just going to get a new battery anyway its almost 5 years old better to have a fresh one anyway.
Quick Reply: Bimmer won't start need our forum gurus...
