Beam malfuntion
got an error today that reads "Left high beam malfuntion" does anybody knows how to reset this error or is the bulb bad?? any help will be apreciated.
Thanks.
Thanks.
I suppose for starters you could set the light control to manual ... activate your high beams and then walk to the front of your car to see if the bulb is on.
Bimmer28 meet Luigi524td
I think the obvious answer here is check your connections and if its not loose then its probably a bad bulb...
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
