Bc button is not working
Old Aug 24, 2016 | 03:07 AM
efy's Avatar
efy
My Ride: 04 525i
Default Bc button is not working
Hey guys
The bc button on the indicator stalk
Is not cycling through the fuel consumption /vspeed etc
There is nothing there above the odometer
Any advice, maybe a fuse?
Thanks in advance
Old Aug 24, 2016 | 07:18 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
fuse sounds unlikely.
each of the individual stalks on the column is connected to a single module within the steering wheel. from what i recall, the connections are pressed in and can be removed pretty easily. perhaps your have a loose connection. does the other button on that stalk work?
Old Aug 25, 2016 | 12:44 PM
efy's Avatar
efy
My Ride: 04 525i
Yeah the check button I believe, that one works, where are these connections? Under the airbag module?
Old Aug 25, 2016 | 12:47 PM
BostonJon's Avatar
Yes, they are under/behind the airbag. Very easy to get to if you have the sport steering wheel with the round airbag. A little more trim to remove if you have the standard steering wheel.
Seems odd to me that one of the buttons works and one doesn't. Try jostling around the stalk near the base.
Old Aug 26, 2016 | 06:57 PM
efy's Avatar
efy
My Ride: 04 525i
Jostling the stalk did nothing, i will remove the airbag and have a look,.... Should i run a scan and post faults found? Would using the carly app be okay for that?
Old Aug 30, 2016 | 06:07 AM
efy's Avatar
efy
My Ride: 04 525i
So I disconnected the battery and when I started the car later, it started working again... Very strange😌
Old Aug 30, 2016 | 06:11 AM
BostonJon's Avatar
very strange, indeed. perhaps disconnecting power somehow reset the module and when it reinitialized it reactivated the button.
Old Aug 30, 2016 | 03:33 PM
efy's Avatar
efy
My Ride: 04 525i
My thoughts exactly... Anyway thanks for your help, much appreciated ☺️
gamblinfool
Oct 4, 2016 10:25 AM
lhe4
Aug 7, 2016 03:29 AM
John E
Aug 6, 2016 03:24 AM
giggy04
Jul 8, 2016 06:15 AM
Motolightnick
Jun 24, 2016 03:32 AM
