Battery Type?
I have an LCI 2008 528i and I am trying to find out what type of battery came with my car. The owners manual didn't say which type is in my car.
I need to charge the battery and it has three settings, AGM, GEL, and standard. So, I would like to know what type I have before I start the charging process.
Thanks,
Todd
Thanks,
Todd
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Thanks,
Todd
Thanks,
Todd
Originally Posted by luigi524td' post='1090111' date='Jan 13 2010, 05:08 PM
If you have a sedan the battery is in a compartment on the right side of the trunk. Unless the battery was changed for some reason I'd select "standard" for charging. My advice, if the battery requires charging, is to have it inspected by a BMW dealer service center - it should be under warranty unless the car was stored and not used for an extended period of time. Even so, if the battery is flat or near dead, in my experience they may come back temporarily and will eventually expire prematurely!!
Thanks,
Todd
Thanks,
Todd
<div class='quotetop'>QUOTE (Todd in AZ @ Jan 13 2010, 03:43 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I have an LCI 2008 528i and I am trying to find out what type of battery came with my car. The owners manual didn't say which type is in my car.
Thanks,
Todd</div>
e60 batteries are AGM type, do you not want to overcharge these batteries.
Thanks,
Todd</div>
I have read lots of threads about battery replacements and whether or not this requires the battery to be registered to the car. My battery was registered and my service manager said that it was required and they had to clear out all of the low voltage faults. My service manager said that the faults would have persisted until the new battery is registered.
